Эта проблема меня пугает
2022-08-11 [20:36:59] [Server thread/CRITICAL]: UnexpectedValueException: "Too many packets in a single batch" (EXCEPTION) in "pmsrc/src/pocketmine/network/Network" at line 296
2022-08-11 [20:36:59] [Server thread/CRITICAL]: #0 pmsrc/src/pocketmine/Player(2417): pocketmine\network\Network->processBatch(object pocketmine\network\mcpe\protocol\BatchPacket, object pocketmine\Player)
2022-08-11 [20:36:59] [Server thread/CRITICAL]: #1 pmsrc/src/pocketmine/network/mcpe/RakLibInterface(184): pocketmine\Player->handleDataPacket(object pocketmine\network\mcpe\protocol\BatchPacket)
2022-08-11 [20:36:59] [Server thread/CRITICAL]: #2 pmsrc/src/raklib/server/ServerHandler(95): pocketmine\network\mcpe\RakLibInterface->handleEncapsulated(string[20] айпи_того_чела 49774, object raklib\protocol\EncapsulatedPacket, integer 0)
2022-08-11 [20:36:59] [Server thread/CRITICAL]: #3 pmsrc/src/pocketmine/network/mcpe/RakLibInterface(114): raklib\server\ServerHandler->handlePacket()
2022-08-11 [20:36:59] [Server thread/CRITICAL]: #4 pmsrc/src/pocketmine/network/mcpe/RakLibInterface(104): pocketmine\network\mcpe\RakLibInterface->process()
2022-08-11 [20:36:59] [Server thread/CRITICAL]: #5 pmsrc/src/pocketmine/snooze/SleeperHandler(123): pocketmine\network\mcpe\RakLibInterface->pocketmine\network\mcpe\{closure}()
2022-08-11 [20:36:59] [Server thread/CRITICAL]: #6 pmsrc/src/pocketmine/snooze/SleeperHandler(82): pocketmine\snooze\SleeperHandler->processNotifications()
2022-08-11 [20:36:59] [Server thread/CRITICAL]: #7 pmsrc/src/pocketmine/Server(2603): pocketmine\snooze\SleeperHandler->sleepUntil(double 1660239419.5223)
2022-08-11 [20:36:59] [Server thread/CRITICAL]: #8 pmsrc/src/pocketmine/Server(2449): pocketmine\Server->tickProcessor()
2022-08-11 [20:36:59] [Server thread/CRITICAL]: #9 pmsrc/src/pocketmine/Server(2022): pocketmine\Server->start()
2022-08-11 [20:36:59] [Server thread/CRITICAL]: #10 pmsrc/src/pocketmine/PocketMine(337): pocketmine\Server->__construct(object BaseClassLoader, object pocketmine\utils\MainLogger, string[11] /root/mcpe/, string[19] /root/mcpe/plugins/)
2022-08-11 [20:36:59] [Server thread/CRITICAL]: #11 pmsrc(1): require_once(string[66] phar:///root/mcpe/PocketMine-MP.phar/src/pocketmine/PocketMine.php)
2022-08-11 [20:36:59] [Server thread/INFO]: udjsh[/айпи_того_чела:49774] отключился: Internal server error
2022-08-11 [20:36:59] [RakLibServer thread/NOTICE]: Blocked айпи_того_чела for 5 seconds
Что?
В батче, отправленного от игрока, оказалось много пакетов
Точнее больше, чем установленный лимит в ядре
возможно лимит изменить?
Ну вроде да. Чекни на какой строке это исключение вылезает. Там наверняка есть сравнение с чем-то. Ну если нет, то попробуй изменить размер мту в раклибе
ок.
Не нужно менять лимит. Этот игрок читер и использовал нюкер, либо другой чит, который отправляет много пакетов
Тоже верно, но Беликов тоже что-то полезное сказал всё-таки.
Лучше не менять лимит сервер может лагать
