Хелп с Termux'ом
Пытаюсь запустить LiteCore 1.0.8 с бинаркой 8
0.24
Выдает это
[11:54:25] [Server thread/WARNING]: ChunkUtils extension is missing. Anvil-format worlds will experience degraded performance.
[11:54:25] [Server thread/WARNING]: Non-packaged LiteCore installation detected. Consider using a phar in production for better performance.
[11:54:25] [Server thread/INFO]: Loading properties and configuration…
[11:54:25] [Server thread/INFO]: Online mode has been turned off in server.properties
[11:54:25] [Server thread/INFO]: Xbox Live authentication is disabled.
[11:54:25] [Server thread/INFO]: Выбран Russian (rus) в качестве главного языка
[11:54:25] [Server thread/INFO]: Открытие сервера на 0.0.0.0:19132
[11:54:25] [Server thread/CRITICAL]: Error: “Class “pocketmine\network\mcpe\protocol\PlayerInputPacket” not found” (EXCEPTION) in “pmsrc/src/pocketmine/network/Network” at line 256
[11:54:25] [Server thread/CRITICAL]: #0 pmsrc/src/pocketmine/network/Network(436): pocketmine\network\Network->registerPacket(integer 57, string[50] pocketmine\network\mcpe\protocol\PlayerInputPacket)
[11:54:25] [Server thread/CRITICAL]: #1 pmsrc/src/pocketmine/network/Network(154): pocketmine\network\Network->registerPackets()
[11:54:25] [Server thread/CRITICAL]: #2 pmsrc/src/pocketmine/Server(1874): pocketmine\network\Network->__construct(object pocketmine\Server)
[11:54:25] [Server thread/CRITICAL]: #3 pmsrc/src/pocketmine/PocketMine(320): pocketmine\Server->__construct(object BaseClassLoader, object pocketmine\utils\MainLogger, string[38] /data/data/com.termux/files/home/mcpe/, string[46] /data/data/com.termux/files/home/mcpe/plugins/)
[11:54:25] [Server thread/EMERGENCY]: Произошла фатальная ошибка и сервер вышел из строя. Создание аварийного дампа
[11:54:25] [Server thread/EMERGENCY]: Пожалуйста, загрузите файл"/data/data/com.termux/files/home/mcpe/crashdumps/CrashDump_Thu_May_16-11.54.25-MSK_2024.log" в краш-архив и отправьте ссылку на страницу исправления ошибок. Дайте как можно больше информации.
[11:54:25] [Server thread/CRITICAL]: Error: “Call to a member function startTiming() on null” (EXCEPTION) in “pmsrc/src/pocketmine/scheduler/AsyncPool” at line 206
[11:54:25] [Server thread/CRITICAL]: #0 pmsrc/src/pocketmine/scheduler/AsyncPool(265): pocketmine\scheduler\AsyncPool->collectTasks()
[11:54:25] [Server thread/CRITICAL]: #1 pmsrc/src/pocketmine/scheduler/ServerScheduler(242): pocketmine\scheduler\AsyncPool->shutdown()
[11:54:25] [Server thread/CRITICAL]: #2 pmsrc/src/pocketmine/Server(2384): pocketmine\scheduler\ServerScheduler->shutdown()
[11:54:25] [Server thread/CRITICAL]: #3 pmsrc/src/pocketmine/Server(2585): pocketmine\Server->forceShutdown()
[11:54:25] [Server thread/CRITICAL]: #4 pmsrc/src/pocketmine/Server(2514): pocketmine\Server->crashDump()
[11:54:25] [Server thread/CRITICAL]: #5 pmsrc/src/pocketmine/Server(2027): pocketmine\Server->exceptionHandler(object Error)
[11:54:25] [Server thread/CRITICAL]: #6 pmsrc/src/pocketmine/PocketMine(320): pocketmine\Server->__construct(object BaseClassLoader, object pocketmine\utils\MainLogger, string[38] /data/data/com.termux/files/home/mcpe/, string[46] /data/data/com.termux/files/home/mcpe/plugins/)
[11:54:25] [Server thread/EMERGENCY]: Crashed while crashing, killing process
Killed
Что делать?
вот
