[LC 1.0.9] NetherLava Help
При создании мира ‘nether’, игрока телепортирует в лаву, и в консоль спамит это:
При пересоздании мира, нечего не пропадает, все равно телепортирует в лаву!
Код ‘\pocketmine\level\generator\populator\NetherLava’:
namespace pocketmine\level\generator\populator;
use pocketmine\block\Block;
use pocketmine\level\ChunkManager;
use pocketmine\utils\Random;
class NetherLava extends Populator{
	private $level;
	private $randomAmount;
	private $baseAmount;
	 * @param $amount
	public function setRandomAmount($amount){
		$this->randomAmount = $amount;
	 * @param $amount
	public function setBaseAmount($amount){
		$this->baseAmount = $amount;
	 * @param ChunkManager $level
	 * @param              $chunkX
	 * @param              $chunkZ
	 * @param Random       $random
	 * @return mixed|void
	public function populate(ChunkManager $level, $chunkX, $chunkZ, Random $random){
		if(mt_rand(0, 100) < 5){
			$this->level = $level;
			$amount = $random->nextRange(0, $this->randomAmount + 1) + $this->baseAmount;
			for($i = 0; $i < $amount; ++$i){
				$x = $random->nextRange($chunkX * 16, $chunkX * 16 + 15);
				$z = $random->nextRange($chunkZ * 16, $chunkZ * 16 + 15);
				$y = $this->getHighestWorkableBlock($x, $z);
				if($y !== -1 and $this->canNetherLavaStay($x, $y, $z)){
					$this->level->setBlockIdAt($x, $y, $z, Block::LAVA);
					$this->level->updateBlockLight($x, $y, $z);
					$this->lavaSpread($x, $y, $z);
	 * @param $x1
	 * @param $y1
	 * @param $z1
	 * @param $x2
	 * @param $y2
	 * @param $z2
	 * @return int
	private function getFlowDecay($x1, $y1, $z1, $x2, $y2, $z2){
		if($this->level->getBlockIdAt($x1, $y1, $z1) !== $this->level->getBlockIdAt($x2, $y2, $z2)){
			return -1;
			return $this->level->getBlockDataAt($x2, $y2, $z2);
	 * @param $x
	 * @param $y
	 * @param $z
	private function lavaSpread($x, $y, $z){
		if($this->level->getChunk($x >> 4, $z >> 4) == null){
		$decay = $this->getFlowDecay($x, $y, $z, $x, $y, $z);
		$multiplier = 2;
		if($decay > 0){
			$smallestFlowDecay = -100;
			$smallestFlowDecay = $this->getSmallestFlowDecay($x, $y, $z, $x, $y, $z - 1, $smallestFlowDecay);
			$smallestFlowDecay = $this->getSmallestFlowDecay($x, $y, $z, $x, $y, $z + 1, $smallestFlowDecay);
			$smallestFlowDecay = $this->getSmallestFlowDecay($x, $y, $z, $x - 1, $y, $z, $smallestFlowDecay);
			$smallestFlowDecay = $this->getSmallestFlowDecay($x, $y, $z, $x + 1, $y, $z, $smallestFlowDecay);
			$k = $smallestFlowDecay + $multiplier;
			if($k >= 8 or $smallestFlowDecay < 0){
				$k = -1;
			if(($topFlowDecay = $this->getFlowDecay($x, $y, $z, $x, $y + 1, $z)) >= 0){
				if($topFlowDecay >= 8){
					$k = $topFlowDecay;
					$k = $topFlowDecay | 0x08;
			if($decay < 8 and $k < 8 and $k > 1 and mt_rand(0, 4) !== 0){
				$k = $decay;
			if($k !== $decay){
				$decay = $k;
				if($decay < 0){
					$this->level->setBlockIdAt($x, $y, $z, 0);
					$this->level->setBlockDataAt($x, $y, $z, $decay);
		if($this->canFlowInto($x, $y - 1, $z)){
			if($decay >= 8){
				$this->flowIntoBlock($x, $y - 1, $z, $decay);
				$this->flowIntoBlock($x, $y - 1, $z, $decay | 0x08);
		}elseif($decay >= 0 and ($decay === 0 or !$this->canFlowInto($x, $y - 1, $z))){
			$flags = $this->getOptimalFlowDirections($x, $y, $z);
			$l = $decay + $multiplier;
			if($decay >= 8){
				$l = 1;
			if($l >= 8){
			if($flags[0]){
				$this->flowIntoBlock($x - 1, $y, $z, $l);
			if($flags[1]){
				$this->flowIntoBlock($x + 1, $y, $z, $l);
			if($flags[2]){
				$this->flowIntoBlock($x, $y, $z - 1, $l);
			if($flags[3]){
				$this->flowIntoBlock($x, $y, $z + 1, $l);
	 * @param $x
	 * @param $y
	 * @param $z
	 * @param $newFlowDecay
	private function flowIntoBlock($x, $y, $z, $newFlowDecay){
		if($this->level->getBlockIdAt($x, $y, $z) === Block::AIR){
			$this->level->setBlockDataAt($x, $y, $z, $newFlowDecay);
	 * @param $x
	 * @param $y
	 * @param $z
	 * @return bool
	private function canFlowInto($x, $y, $z){
		$id = $this->level->getBlockIdAt($x, $y, $z);
		if($id === Block::AIR or $id === Block::LAVA or $id === Block::STILL_LAVA){
	 * @param $xx
	 * @param $yy
	 * @param $zz
	 * @param $accumulatedCost
	 * @param $previousDirection
	 * @return int
	private function calculateFlowCost($xx, $yy, $zz, $accumulatedCost, $previousDirection){
		$cost = 1000;
		for($j = 0; $j < 4; ++$j){
			if(
				($j === 0 and $previousDirection === 1) or
				($j === 1 and $previousDirection === 0) or
				($j === 2 and $previousDirection === 3) or
				($j === 3 and $previousDirection === 2)
				$x = $xx;
				$y = $yy;
				$z = $zz;
				if($j === 0){
					--$x;
				}elseif($j === 1){
					++$x;
				}elseif($j === 2){
					--$z;
				}elseif($j === 3){
					++$z;
				if(!$this->canFlowInto($x, $y, $z)){
					continue;
				}elseif($this->canFlowInto($x, $y, $z) and $this->level->getBlockDataAt($x, $y, $z) === 0){
					continue;
				}elseif($this->canFlowInto($x, $y - 1, $z)){
					return $accumulatedCost;
				if($accumulatedCost >= 4){
					continue;
				$realCost = $this->calculateFlowCost($x, $y, $z, $accumulatedCost + 1, $j);
				if($realCost < $cost){
					$cost = $realCost;
		return $cost;
	 * @param $xx
	 * @param $yy
	 * @param $zz
	 * @return array
	private function getOptimalFlowDirections($xx, $yy, $zz){
		$flowCost = [0, 0, 0, 0];
		$isOptimalFlowDirection = [0, 0, 0, 0];
			$flowCost[$j] = 1000;
			$x = $xx;
			$y = $yy;
			$z = $zz;
			if($j === 0){
				--$x;
			}elseif($j === 1){
				++$x;
			}elseif($j === 2){
				--$z;
			}elseif($j === 3){
				++$z;
				continue;
				continue;
				$flowCost[$j] = 0;
				$flowCost[$j] = $this->calculateFlowCost($x, $y, $z, 1, $j);
		$minCost = $flowCost[0];
		for($i = 1; $i < 4; ++$i){
			if($flowCost[$i] < $minCost){
				$minCost = $flowCost[$i];
		for($i = 0; $i < 4; ++$i){
			$isOptimalFlowDirection[$i] = ($flowCost[$i] === $minCost);
		return $isOptimalFlowDirection;
	 * @param $x1
	 * @param $y1
	 * @param $z1
	 * @param $x2
	 * @param $y2
	 * @param $z2
	 * @param $decay
	 * @return int
	private function getSmallestFlowDecay($x1, $y1, $z1, $x2, $y2, $z2, $decay){
		$blockDecay = $this->getFlowDecay($x1, $y1, $z1, $x2, $y2, $z2);
		if($blockDecay < 0){
			return $decay;
		}elseif($blockDecay === 0){
			//Nothing to do!
		}elseif($blockDecay >= 8){
			$blockDecay = 0;
		return ($decay >= 0 && $blockDecay >= $decay) ? $decay : $blockDecay;
	 * @param $x
	 * @param $y
	 * @param $z
	 * @return bool
	private function canNetherLavaStay($x, $y, $z){
		$b = $this->level->getBlockIdAt($x, $y, $z);
		return $b === Block::AIR;
	 * @param $x
	 * @param $z
	 * @return int
	private function getHighestWorkableBlock($x, $z){
		for($y = 127; $y >= 0; --$y){
			if($b == Block::AIR){
		return $y === 0 ? -1 : $y;
Лава делает с твоим сервером примерно то что у тебя на аве
ХАХАХАХАХ ясн
это он так исправил, кто не понял
@qrvgqwe учись
ахах он удалил
ну я только учу не знаю что за звездочки что за что отвечают скобочки я только json знаю
Так зачем давать человеку ложные надежды
Я удалил строку хз зачем
не фикс ли с аеры?
