— Stack trace —
12 #0 (): pocketmine\errorhandler\ErrorToExceptionHandler::handle(int 2, string[103] yaml_parse(): reading error encountered during parsing: invalid trailing UTF-8 o, string[59] phar:///server/server.phar/src/plugin/PluginDescription.php, int 90)
13 #1 pmsrc/src/plugin/PluginDescription(90): yaml_parse(string[560] name: BedrockClans.main: Wertzui123\BedrockClans\Main.version: 3.6.api: 4.0.0.lo)
14 #2 plugins/DevTools.phar/src/FolderPluginLoader(58): pocketmine\plugin\PluginDescription->__construct(string[560] name: BedrockClans.main: Wertzui123\BedrockClans\Main.version: 3.6.api: 4.0.0.lo)
15 #3 pmsrc/src/plugin/PluginManager(253): DevTools\FolderPluginLoader->getPluginDescription(string[32] /server/plugins/BedrockClans-3.6)
16 #4 pmsrc/src/plugin/PluginManager(373): pocketmine\plugin\PluginManager->triagePlugins(string[16] /server/plugins/, object pocketmine\plugin\PluginLoadTriage#25747, int 0, array[1])
17 #5 pmsrc/src/Server(1007): pocketmine\plugin\PluginManager->loadPlugins(string[16] /server/plugins/, int 0)
18 #6 pmsrc/src/PocketMine(304): pocketmine\Server->__construct(object BaseClassLoader#3, object pocketmine\utils\MainLogger#2, string[8] /server/, string[16] /server/plugins/)
19 #7 pmsrc/src/PocketMine(327): pocketmine\server()
20 #8 pmsrc(11): require(string[45] phar:///server/server.phar/src/PocketMine.php)
21 — End of exception information —
22 2022-10-16 [16:54:56.889] [Server thread/EMERGENCY]: An unrecoverable error has occurred and the server has crashed. Creating a crash dump
23 2022-10-16 [16:54:56.892] [Server thread/EMERGENCY]: Please upload the “/server/crashdumps/Sun_Oct_16-16.54.56-+06_2022.log” file to the Crash Archive and submit the link to the Bug Reporting page. Give as much info as you can.
24 2022-10-16 [16:54:56.892] [Server thread/EMERGENCY]: Forcing server shutdown
Неверный завершающий код UTF-8
Если быть точнее, не корректный plugin.yml
ну да
при нажатии ведет на сайт про кредиты
всм, не я автор этой темы, а @gamingpusto
понял, соррян
та ничего страшного
Кидайте жб
с первого флажка)
там 3 ссылки на один и тот же сайт… А самое главное - зачем?
