Помогите пожалуйста, что за проблема
Захожу с лаунчера на сервер и тут появляется ошибка
[19:46:40] [LunCore/ИНФО]: Steve присоединился к игре
[19:46:40] [LunCore/КРИТ]: Error: “Class “pocketmine\network\protocol\EntityEventPacket” not found” (EXCEPTION) in “pmsrc/src/pocketmine/entity/Living” at line 110
[19:46:40] [LunCore/КРИТ]: #0 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(73): pocketmine\entity\Living->attack(double 2, object pocketmine\event\entity\EntityDamageEvent)
[19:46:40] [LunCore/КРИТ]: #1 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(722): pocketmine\entity\Creature->attack(double 2, object pocketmine\event\entity\EntityDamageEvent)
[19:46:40] [LunCore/КРИТ]: #2 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(3951): pocketmine\entity\Human->attack(double 2, object pocketmine\event\entity\EntityDamageEvent)
[19:46:40] [LunCore/КРИТ]: #3 pmsrc/src/pocketmine/entity/Living(179): pocketmine\Player->attack(integer 2, object pocketmine\event\entity\EntityDamageEvent)
[19:46:40] [LunCore/КРИТ]: #4 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(51): pocketmine\entity\Living->entityBaseTick(integer 1, integer 0)
[19:46:40] [LunCore/КРИТ]: #5 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(702): pocketmine\entity\Creature->entityBaseTick(integer 1, integer 0)
[19:46:40] [LunCore/КРИТ]: #6 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(1622): pocketmine\entity\Human->entityBaseTick(integer 1)
[19:46:40] [LunCore/КРИТ]: #7 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(751): pocketmine\Player->onUpdate(integer 398)
[19:46:40] [LunCore/КРИТ]: #8 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(683): pocketmine\level\Level->actuallyDoTick(integer 398)
[19:46:40] [LunCore/КРИТ]: #9 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(2415): pocketmine\level\Level->doTick(integer 398)
[19:46:40] [LunCore/КРИТ]: #10 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(2563): pocketmine\Server->checkTickUpdates(integer 398, double 1658692000.0007)
[19:46:40] [LunCore/КРИТ]: #11 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(2323): pocketmine\Server->tick()
[19:46:40] [LunCore/КРИТ]: #12 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(2183): pocketmine\Server->tickProcessor()
[19:46:40] [LunCore/КРИТ]: #13 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(1809): pocketmine\Server->start()
[19:46:40] [LunCore/КРИТ]: #14 pmsrc/src/pocketmine/PocketMine(304): pocketmine\Server->__construct(object BaseClassLoader, object pocketmine\utils\MainLogger, string[12] /root/grief/, string[20] /root/grief/plugins/)
[19:46:40] [LunCore/КРИТv2]: Произошла фатальная ошибка и сервер вышел из строя. Создание аварийного дампа
[19:46:40] [LunCore/КРИТv2]: Пожалуйста, загрузите файл"/root/grief/crashdumps/CrashDump_Sun_Jul_24-19.46.40-UTC_2022.log" в краш-архив и отправьте ссылку на страницу исправления ошибок. Дайте как можно больше информации.
Как это исправить?
Добавь юз
use pocketmine\network\protocol\EntityEventPacket;
В
pocketmine/entity/Living.php
по крайней мере юзай Aquamarine.
@Marusel, :>
2 симпатии
Он итак добавлен туда
тогда не советую ЛунКор
божечки, русский язык
Значит создатель лунКор зачем то удалил этот пакет…
pocketmine\network\mcpe\protocol\EntityEventPacket
Вы не забывайте, што все легендарные и топовые ядра основаны на лайткор
Это еще с генки
