Проблема с FlyText
Запускаю сервер с установленным плагином FlyText, и сразу же выдает это:
[16:58:17] [Unknown\CRITICAL]: Could not execute task pocketmine\scheduler\CallbackTask: pocketmine\level\particle\FloatingTextParticle::__construct(): Argument #1 ($O9130896728071678700) must be of type pocketmine\level\Position, pocketmine\math\Vector3 given, called in /root/UN/plugins/FlyText/src/Richen/FlyText.php on line 39
[16:58:17] [Unknown\CRITICAL]: TypeError: “pocketmine\level\particle\FloatingTextParticle::__construct(): Argument #1 ($O9130896728071678700) must be of type pocketmine\level\Position, pocketmine\math\Vector3 given, called in /root/UN/plugins/FlyText/src/Richen/FlyText.php on line 39” (EXCEPTION) in “pmsrc/src/pocketmine/level/particle/FloatingTextParticle” at line 32
[16:58:17] [Unknown\CRITICAL]: #0 plugins/FlyText/src/Richen/FlyText(39): pocketmine\level\particle\FloatingTextParticle->__construct(object pocketmine\math\Vector3, string[4] Test, string[4] Test)
[16:58:17] [Unknown\CRITICAL]: #1 (): Richen\FlyText->addParticles(object pocketmine\scheduler\CallbackTask)
[16:58:17] [Unknown\CRITICAL]: #2 pmsrc/src/pocketmine/scheduler/CallbackTask(35): call_user_func_array(array[2], array[1])
[16:58:17] [Unknown\CRITICAL]: #3 pmsrc/src/pocketmine/scheduler/TaskHandler(126): pocketmine\scheduler\CallbackTask->onRun(integer 1)
[16:58:17] [Unknown\CRITICAL]: #4 pmsrc/src/pocketmine/scheduler/ServerScheduler(346): pocketmine\scheduler\TaskHandler->run(integer 1)
[16:58:17] [Unknown\CRITICAL]: #5 pmsrc/src/pocketmine/Server(4854): pocketmine\scheduler\ServerScheduler->mainThreadHeartbeat(integer 1)
[16:58:17] [Unknown\CRITICAL]: #6 pmsrc/src/pocketmine/Server(4271): pocketmine\Server->tick()
[16:58:17] [Unknown\CRITICAL]: #7 pmsrc/src/pocketmine/Server(3915): pocketmine\Server->tickProcessor()
[16:58:17] [Unknown\CRITICAL]: #8 pmsrc/src/pocketmine/Server(2900): pocketmine\Server->start()[16:58:17] [Unknown\CRITICAL]: #9 pmsrc/src/pocketmine/PocketMine(374): pocketmine\Server->__construct(object BaseClassLoader, object pocketmine\utils\MainLogger, string[12] /root/UN/, string[20] /root/UN/plugins/)
Пытался с ИИ что-то сделать, но я для этого недостаточно шарю.
:moai:
ти чо? читать ошибку для тупых
Не не, я рил не вдупляю. Я даже базу не знаю, но знаю сложить 2+2👾
Так нахера… выучи базу сначало…
Просто ищу быстрое решение. Конечно, выучить язык и самому всем этим разобраться может лучше, но мне лень🖤
не хочешь срать .не мучай жоп-
У меня другой случай, и с вашей фразой это не как не связано.
Связано, не хоч учится не мучай форум
Мучаю? Капец я садист.
ты вместо Position написал Vector3 в вызове партикла FloatingTextParticle
Давай на пальчиках объясню.
Представим, что ты строишь башню из кубиков Лего. У тебя есть инструкция: поставь зелёный кубик на красный. А ты берёшь синий треугольник. Инструкция говорит: “Эй! Я просил кубик, а не треугольник!”
Теперь по-простому к твоей ошибке:
У тебя есть функция-конструктор:
Она говорит: “Дай мне Position!” — это как красный кубик, специальный тип.
А ты ей дал:
Vector3
Это похожая штука, но не совсем то. Это как будто дал треугольник тоже с координатами (x, y, z), но без информации о мире (level), которой не хватает, чтобы правильно работать.
Как исправить:
Нужно вместо new Vector3(...) использовать new Position(...), например:
use pocketmine\level\Position;
$pos = new Position($x, $y, $z, $level);
$text = new FloatingTextParticle($pos, "Заголовок", "Описание");
Position = Vector3 + мир (Level)
А FloatingTextParticle обязательно хочет знать и координаты, и в каком мире это происходит.
Надеюсь понятно объяснил?
4 лайка
Большое спасибо за такой подробный разбор. Суть я понял, но столкнулся с ещё одной проблемой. В любом случае, спасибо!:alien_monster:
Были бы у нас такие преподы
хахахаххаха
