Проблема с MeowChat
Захожу с лаунчера на сервер и меня кикает и появляется ошибка
[19:47:50] [LunCore/КРИТ]: Error: “Class “pocketmine\network\protocol\EntityEventPacket” not found” (EXCEPTION) in “pmsrc/src/pocketmine/entity/Living” at line 110
[19:47:50] [LunCore/КРИТ]: #0 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(73): pocketmine\entity\Living->attack(double 2, object pocketmine\event\entity\EntityDamageEvent)
[19:47:50] [LunCore/КРИТ]: #1 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(722): pocketmine\entity\Creature->attack(double 2, object pocketmine\event\entity\EntityDamageEvent)
[19:47:50] [LunCore/КРИТ]: #2 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(3951): pocketmine\entity\Human->attack(double 2, object pocketmine\event\entity\EntityDamageEvent)
[19:47:50] [LunCore/КРИТ]: #3 pmsrc/src/pocketmine/entity/Living(179): pocketmine\Player->attack(integer 2, object pocketmine\event\entity\EntityDamageEvent)
[19:47:50] [LunCore/КРИТ]: #4 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(51): pocketmine\entity\Living->entityBaseTick(integer 1, integer 0)
[19:47:50] [LunCore/КРИТ]: #5 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(702): pocketmine\entity\Creature->entityBaseTick(integer 1, integer 0)
[19:47:50] [LunCore/КРИТ]: #6 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(1622): pocketmine\entity\Human->entityBaseTick(integer 1)
[19:47:50] [LunCore/КРИТ]: #7 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(751): pocketmine\Player->onUpdate(integer 244)
[19:47:50] [LunCore/КРИТ]: #8 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(683): pocketmine\level\Level->actuallyDoTick(integer 244)
[19:47:50] [LunCore/КРИТ]: #9 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(2415): pocketmine\level\Level->doTick(integer 244)
[19:47:50] [LunCore/КРИТ]: #10 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(2563): pocketmine\Server->checkTickUpdates(integer 244, double 1658519270.5845)
[19:47:50] [LunCore/КРИТ]: #11 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(2323): pocketmine\Server->tick()
[19:47:50] [LunCore/КРИТ]: #12 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(2183): pocketmine\Server->tickProcessor()
[19:47:50] [LunCore/КРИТ]: #13 pmsrc/src/pocketmine/ThreadManager(166) : eval()'d code(1) : eval()'d code(1809): pocketmine\Server->start()
[19:47:50] [LunCore/КРИТ]: #14 pmsrc/src/pocketmine/PocketMine(304): pocketmine\Server->__construct(object BaseClassLoader, object pocketmine\utils\MainLogger, string[12] /root/grief/, string[20] /root/grief/plugins/)
[19:47:50] [LunCore/КРИТv2]: Произошла фатальная ошибка и сервер вышел из строя. Создание аварийного дампа
[19:47:50] [LunCore/КРИТv2]: Пожалуйста, загрузите файл"/root/grief/crashdumps/CrashDump_Fri_Jul_22-19.47.50-UTC_2022.log" в краш-архив и отправьте ссылку на страницу исправления ошибок. Дайте как можно больше информации.
Помогите пожалуйста
MeowChat.zip (15.1 КБ)
хм
	function getFaction(Player $player){
		$name = strtolower($player->getName());
		if($this->getFactions() !== null){
			$f = $this->getFactions();
			$clan = $f->getPlayerFaction($name);
			return $clan !== null ? $clan : $this->getConfig()->get("ClanNone", "x");
		return $this->getConfig()->get("ClanNone", "x");
	//110 line
	function onJoin(PlayerJoinEvent $event){
		$data = $this->getConfig()->getAll();
		$group = $this->getPurePerms()->getUserDataMgr()->getGroup($player)->getName();
		if(!empty($data[$group])){
			$nameTag = $this->getNameTag($player, $group);
			$displayName = $this->getDisplayName($player, $group);
			$player->sendMessage(" К сожалению, ваш чат не будет отображаться, поскольку в базе не заполнены форматы для группы §c". $group);
			$nameTag = "§8[§b". $group ."§8] §f". $player->getName();
			$displayName = "§b§l". $player->getName() ."§r";
		$player->setNameTag($nameTag);
		$player->setDisplayName($displayName);
Добавь юз
use pocketmine\network\protocol\EntityEventPacket;
В pocketmine\entity\Living.php
ех, халясё, сё я ня пиэмэмпи четыре сизю, у миня праблем нет :heart: :heart: :heart:
