ядро pmmp
BAD PLUGIN: SexGuard
Error: str_replace(): Argument #2 ($replace) must be of type string when argument #1 ($search) is a string
File: plugins/Regions/src/sex/guard/listener/player/PlayerInteractListener
Line: 160
Type: TypeError
Backtrace:
#0 plugins/Regions/src/sex/guard/listener/player/PlayerInteractListener(160): str_replace(string[10] {max_size}, array[1], string[87] …l…c- …fGUARD …c- … …: {max_size} …)
#1 pmsrc/src/event/RegisteredListener(60): sex\guard\listener\player\PlayerInteractListener->onEvent(object pocketmine\event\player\PlayerInteractEvent#174738)
#2 pmsrc/src/event/Event(62): pocketmine\event\RegisteredListener->callEvent(object pocketmine\event\player\PlayerInteractEvent#174738)
#3 pmsrc/src/world/World(1792): pocketmine\event\Event->call()
#4 pmsrc/src/player/Player(1683): pocketmine\world\World->useItemOn(object pocketmine\math\Vector3#100445, object pocketmine\item\Axe#99156, int 1, object pocketmine\math\Vector3#139736, object pocketmine\player\Player#120975, true)
#5 pmsrc/src/network/mcpe/handler/InGamePacketHandler(441): pocketmine\player\Player->interactBlock(object pocketmine\math\Vector3#100445, int 1, object pocketmine\math\Vector3#139736)
#6 pmsrc/src/network/mcpe/handler/InGamePacketHandler(299): pocketmine\network\mcpe\handler\InGamePacketHandler->handleUseItemTransaction(object pocketmine\network\mcpe\protocol\types\inventory\UseItemTransactionData#180281)
#7 pmsrc/vendor/pocketmine/bedrock-protocol/src/InventoryTransactionPacket(105): pocketmine\network\mcpe\handler\InGamePacketHandler->handleInventoryTransaction(object pocketmine\network\mcpe\protocol\InventoryTransactionPacket#138044)
#8 pmsrc/src/network/mcpe/NetworkSession(392): pocketmine\network\mcpe\protocol\InventoryTransactionPacket->handle(object pocketmine\network\mcpe\handler\InGamePacketHandler#96924)
#9 pmsrc/src/network/mcpe/NetworkSession(355): pocketmine\network\mcpe\NetworkSession->handleDataPacket(object pocketmine\network\mcpe\protocol\InventoryTransactionPacket#138044, string[56] …;…gf.B.zvB,X.C…?..?..0?..)
#10 pmsrc/src/network/mcpe/raklib/RakLibInterface(182): pocketmine\network\mcpe\NetworkSession->handleEncoded(string[56] c.a:.h!..;.F. .b…NO…t".;70q.304.3.3…e…)
#11 pmsrc/vendor/pocketmine/raklib-ipc/src/RakLibToUserThreadMessageReceiver(42): pocketmine\network\mcpe\raklib\RakLibInterface->onPacketReceive(int 6, string[65] …F…H…}“).D.Z/..y.g=.;…7…,x.c0y…l…”…3…h.G)
#12 pmsrc/src/network/mcpe/raklib/RakLibInterface(112): raklib\server\ipc\RakLibToUserThreadMessageReceiver->handle(object pocketmine\network\mcpe\raklib\RakLibInterface#33163)
#13 pmsrc/vendor/pocketmine/snooze/src/SleeperHandler(123): pocketmine\network\mcpe\raklib\RakLibInterface->pocketmine\network\mcpe\raklib{closure}()
#14 pmsrc/vendor/pocketmine/snooze/src/SleeperHandler(82): pocketmine\snooze\SleeperHandler->processNotifications()
#15 pmsrc/src/Server(1703): pocketmine\snooze\SleeperHandler->sleepUntil(float 1658303999.1752)
#16 pmsrc/src/Server(1063): pocketmine\Server->tickProcessor()
#17 pmsrc/src/PocketMine(304): pocketmine\Server->__construct(object BaseClassLoader#2, object pocketmine\utils\MainLogger#3, string[10] /srv/data/, string[18] /srv/data/plugins/)
#18 pmsrc/src/PocketMine(327): pocketmine\server()
#19 pmsrc(11): require(string[54] phar:///srv/data/PocketMine-MP.phar/src/PocketMine.php)
Code:
[151] unset($api->position[0][$nick]);
[152] $api->sendWarning($player, $api->getValue(‘pos_another_world’));
[153] return;
[154] }
[155]
[156] $val = $api->getGroupValue($player);
[157] $size = $api->calculateSize($api->position[0][$nick], $clickedBlockPos);
[158]
[159] if($size > $val[‘max_size’] and !$player->hasPermission(‘sexguard.all’)){
[160] $msg = str_replace(‘{max_size}’, (array) $val[‘max_size’], $api->getValue(‘rg_oversize’));
[161]
[162] $api->sendWarning($player, $msg);
[163] return;
[164] }
[165]
[166] $api->position[1][$nick] = $clickedBlockPos;
[167]
[168] $api->sendWarning($player, $api->getValue(‘pos_2_set’));
[169] return;
[170] }
