CrashDump, help
LiteCore-public v1.0.9-release Crash Dump Tue Jan 3 22:21:58 MSK 2023
Error: yaml_parse(): scanning error encountered during parsing: did not find expected comment or line break (line 7, column 25), context while scanning a block scalar (line 7, column 22)
File: pmsrc/src/pocketmine/utils/Config
Line: 151
Type: ErrorException
A PLUGIN WAS INVOLVED IN THIS CRASH
142] case Config::PROPERTIES:
[143] case Config::CNF:
[144] $this->parseProperties($content);
[145] break;
[146] case Config::JSON:
[147] $this->config = json_decode($content, true);
[148] break;
[149] case Config::YAML:
[150] $content = self::fixYAMLIndexes($content);
[151] $this->config = yaml_parse($content);
[152] break;
[153] case Config::SERIALIZED:
[154] $this->config = unserialize($content);
[155] break;
[156] case Config::ENUM:
[157] $this->parseList($content);
[158] break;
[159] default:
[160] $this->correct = false;
[161]
thread/CRITICAL]: ErrorException: “yaml_parse(): scanning error encountered during parsing: did not find expected comment or line break (line 7, column 25), context while scanning a block scalar (line 7, column 22)” (EXCEPTION) in “pmsrc/src/pocketmine/utils/Config” at line 151
[22:26:56] [Server thread/CRITICAL]: #0 (): pocketmine\utils\Utils::errorExceptionHandler(integer 2, string[179] yaml_parse(): scanning error encountered during parsing: did not find expected c, string[41] /srv/data/src/pocketmine/utils/Config.php, integer 151)
[22:26:56] [Server thread/CRITICAL]: #1 pmsrc/src/pocketmine/utils/Config(151): yaml_parse(string[3685] —.enable-multiworld-support: false.custom-no-fac-message: ‘… …’.)
[22:26:56] [Server thread/CRITICAL]: #2 pmsrc/src/pocketmine/utils/Config(83): pocketmine\utils\Config->load(string[37] /srv/data/plugins/PureChat/config.yml, integer -1, array[0])
[22:26:56] [Server thread/CRITICAL]: #3 pmsrc/src/pocketmine/plugin/PluginBase(286): pocketmine\utils\Config->__construct(string[37] /srv/data/plugins/PureChat/config.yml)
[22:26:56] [Server thread/CRITICAL]: #4 pmsrc/src/pocketmine/plugin/PluginBase(255): pocketmine\plugin\PluginBase->reloadConfig()
[22:26:56] [Server thread/CRITICAL]: #5 plugins/PureChatPRO.phar/src/_64FF00/PureChat/PureChat(27): pocketmine\plugin\PluginBase->getConfig()
[22:26:56] [Server thread/CRITICAL]: #6 pmsrc/src/pocketmine/plugin/PharPluginLoader(112): _64FF00\PureChat\PureChat->onLoad()
[22:26:56] [Server thread/CRITICAL]: #7 pmsrc/src/pocketmine/plugin/PharPluginLoader(65): pocketmine\plugin\PharPluginLoader->initPlugin(object _64FF00\PureChat\PureChat, object pocketmine\plugin\PluginDescription, string[26] /srv/data/plugins/PureChat, string[41] phar:///srv/data/plugins/PureChatPRO.phar)
[22:26:56] [Server thread/CRITICAL]: #8 pmsrc/src/pocketmine/plugin/PluginManager(158): pocketmine\plugin\PharPluginLoader->loadPlugin(string[41] phar:///srv/data/plugins/PureChatPRO.phar)
[22:26:56] [Server thread/CRITICAL]: #9 pmsrc/src/pocketmine/plugin/PluginManager(360): pocketmine\plugin\PluginManager->loadPlugin(string[34] /srv/data/plugins/PureChatPRO.phar, array[3])
[22:26:56] [Server thread/CRITICAL]: #10 pmsrc/src/pocketmine/Server(1927): pocketmine\plugin\PluginManager->loadPlugins(string[18] /srv/data/plugins/)
[22:26:56] [Server thread/CRITICAL]: #11 pmsrc/src/pocketmine/PocketMine(337): pocketmine\Server->__construct(object BaseClassLoader, object pocketmine\utils\MainLogger, string[10] /srv/data/, string[18] /srv/data/plugins/)
[22:26:56] [Server thread/EMERGENCY]: Произошла фатальная ошибка и сервер вышел из строя. Создание аварийного дампа
[22:26:56] [Server thread/EMERGENCY]: Пожалуйста, загрузите файл"/srv/data/crashdumps/CrashDump_Tue_Jan_3-22.26.56-MSK_2023.log" в краш-архив и отправьте ссылку на страницу исправления ошибок. Дайте как можно больше информации.
— Waiting 120 seconds to throttle automatic restart (you can kill the process safely now) —
Ты криворукий редачер
PureChatPRO говно он только для школа серверов уже у всех свой плагин на чаты
Юзай более адекватные альтернативы PureChata
Если ты про свой “адекватный плагин” то я лучше умру чем это буду использовать
ААААААААААААААААААААААААААААААААА
Что выбрать
CCCP
https://atomicheart.vkplay.ru/_nuxt/img/block1-slide-1.5462ffb.jpg
Russia
https://vgtimes.ru/uploads/posts/2021-03/thumbs/1614870120_mwfhmzhlyjyncjtjrxdvi2rsbxmbtmf1m0p3wedudwe-xhrcrwokoymakaohqiolmxgsdrhcpttpct0trxp8ecibpgoedtr4iwuvhwxdftf1xi5oxlvgynrzk1dcchphawp4hlfbfwd0w3wbcv91mnuobwc.jpg
Всех с 2077
А я и не упомянул свой плагин
