CurseStone C , C++ / mcpe 0.15
CurseStone: open source server software for Minecraft PE 0.15.x (v1.0.1)
Introducing CurseStone, server software for Minecraft: Pocket Edition 0.15.x (protocol 84), written in C and C++. It is now open source under the LGPL-3.0-or-later license.
What it has so far
  • Lua 5.4 plugin system, built into the binary (nothing extra to install).
  • Two world formats: Anvil (default) and LevelDB.
  • Terrain generation with biomes, trees, caves, villages and desert temples.
  • Permissions, permission-aware commands, hunger, environmental damage and crafting.
  • Built-in diagnostics tools (/workbench) and crash reports.
  • Runs on Linux and Android (Termux), and can be built for Windows and macOS.
Project status
CurseStone still has bugs and is not ready to run a stable server yet. It is under active development: it can crash, change between releases and break compatibility (for example, 1.0.1 renamed some config keys). Do not use it yet for a serious server with real players.
How you can help
Anyone can contribute: reporting bugs, testing the server, improving the documentation or sending code as a pull request. If you find a bug, open an issue with the steps to reproduce it and the log or crash dump.
Links
Feedback, suggestions and help are welcome.
Bro :skull::folded_hands:
нормально))))
ии жеска надристала
это пиздeц
It was initially made as a private project for the Craftsman 0.15 community, but I decided to make it public.
yo gl with the grind
the project looks clean ngl, keep it up
