CurseStone: open source server software for Minecraft PE 0.15.x (v1.0.2)
Autor: Dr1xyDev
CurseStone v1.0.2 Beta Release
Changes since Beta v1.0.1.5.
Added
- Added Windows x86-64 build support, MSVC compatibility, Windows startup scripts, and platform-specific release archives.
- Added Nether portals, portal linking, coordinate conversion, and travel between the Overworld and Nether.
- Added multiworld management, independent world ticking, world loading and unloading, and autosaving.
- Added Nether terrain generation improvements, including bedrock boundaries, glowstone clusters, and fire placement.
- Added vanilla-style beds with sleeping animations, spawn points, player synchronization, and nighttime skipping when all players in a world are asleep.
- Added hunger and food mechanics, including saturation, exhaustion, regeneration, starvation, and persistent player data.
- Added food items, including baked potatoes, beetroot, beetroot soup, fish, mutton, rabbit, rabbit stew, cookies, pumpkin pie, golden carrots, enchanted golden apples, rotten flesh, and spider eyes.
- Added drinkable potions, splash potions, projectile collisions, shatter effects, and area-based effect application.
- Added 23 status effects: Speed, Slowness, Haste, Mining Fatigue, Strength, Instant Health, Instant Damage, Jump Boost, Nausea, Regeneration, Resistance, Fire Resistance, Water Breathing, Invisibility, Blindness, Night Vision, Hunger, Weakness, Poison, Wither, Health Boost, Absorption, and Saturation.
- Added milk buckets that remove active status effects and leave an empty bucket.
- Added bow drawing and release mechanics, arrow flight, projectile collisions, arrow pickup, and despawning.
- Added falling-block physics for sand, gravel, and anvils.
- Added custom item names and improved NBT preservation across inventories, equipment, containers, and dropped items.
- Expanded the Lua plugin API with world management, player manipulation, resource access, and additional player, entity, bed, door, and interaction events.
- Added Lua command overrides with automatic restoration of built-in commands when plugins unload.
- Added Lua execution limits and automatic plugin disabling after repeated errors or excessive execution time.
- Added
/kill <player>and the operator-only/statuscommand with TPS, memory, uptime, player count, plugin count, and world diagnostics. - Added a first-run setup wizard, embedded default configuration templates, and startup scripts for Linux, Termux, and Windows.
- Added Doxygen documentation generation, automated publishing, development guidelines, and code-formatting rules.
Changed
- Separated basic settings in
server.propertiesfrom advanced settings incursestone.yml. - Moved plugin data storage to the server-root
data_pl/directory. - Updated the server and plugin API version to
1.0.2. - Improved damage calculations for environmental damage, armor, creative mode, resistance, strength, weakness, and absorption.
- Improved multiplayer synchronization for health, hunger, food consumption, equipment, item use, bows, arrows, knockback, death, respawning, and item pickup.
- Improved player data persistence for health, hunger, saturation, exhaustion, active effects, and bed spawn positions.
- Optimized incremental chunk autosaving across loaded worlds.
- Improved item-stack validation, maximum stack sizes, and NBT-aware item merging.
- Improved Windows portability and linked zlib and LevelDB statically to avoid missing runtime DLL dependencies.
- Standardized source formatting and comments and removed obsolete source stubs and outdated test utilities.
Fixed
- Fixed Nether portal detection, ignition, metadata, linking, and dimension travel.
- Fixed beds and doors becoming ghost blocks or failing to synchronize correctly.
- Fixed bed sleeping animations and sleep data synchronization.
- Fixed chunk streaming and login packet ordering to improve initial chunk delivery.
- Fixed falling-block network entity IDs and client rendering.
- Fixed fire interactions, environmental damage, and fall damage.
- Fixed potion rendering, splash shatter effects, and status-effect synchronization on MCPE 0.15.10.
- Fixed multiplayer food consumption, milk usage, health updates, and hunger synchronization.
- Fixed multiplayer bow animations, arrow spawning, projectile movement, and release behavior.
- Fixed dropped items remaining visible after pickup and improved item synchronization between players.
- Fixed item duplication, invalid stack sizes, and incorrect merging of items with different NBT data.
- Fixed custom item names and NBT data being lost during inventory, container, equipment, and death-drop operations.
- Fixed player death and respawn handling and chest block-event packet handling.
- Fixed plugin event bindings and message handling.
- Fixed operator-list parsing on Android, including UTF-16 files and inconsistent entry formatting.
- Fixed Windows compilation, threading, POSIX compatibility, and release packaging issues.
- Fixed startup configuration defaults and behavior when configuration files are missing.
Notes
- Target client: Minecraft: Pocket Edition 0.15.x.
- Network protocol: 84.
- CurseStone is server software and does not implement every vanilla Minecraft mechanic.
- Some features may require additional in-game testing to verify complete client compatibility.
CurseStone v1.0.2 Beta Release is now available
Project status
CurseStone is still under active development and is not yet ready for stable production servers. Bugs, crashes, and breaking changes may occur.
Links
- Website: https://cursestone.pages.dev
- Source code: GitHub - CurseStoneTeam/CurseStone: SERVER SOFTWARE for mcpe writed in c and c++ · GitHub
- GitHub Releases: Releases · CurseStoneTeam/CurseStone · GitHub
Feedback, suggestions, and contributions are welcome ![]()
