INFO:vkbottle:logging is used as the default logger, but we recommend using loguru. It may also become a required dependency in future releases.
WARNING:vkbottle:Blueprints was deprecated and will be removed in future releases, read about new code separation method in documentation:
https://vkbottle.readthedocs.io/ru/latest/tutorial/code-separation/
Traceback (most recent call last):
File "/root/Admin/main.py", line 1, in <module>
from loader import user
File "/root/Admin/loader.py", line 4, in <module>
from handlers import *
File "/root/Admin/handlers/__init__.py", line 1, in <module>
from . import commands
File "/root/Admin/handlers/commands.py", line 2, in <module>
from utils.users import get_appeal_id, mention
File "/root/Admin/utils/__init__.py", line 1, in <module>
from . import users
File "/root/Admin/utils/users.py", line 1, in <module>
from vkbottle import Message
ImportError: cannot import name 'Message' from 'vkbottle' (/usr/local/lib/python3.10/dist-packages/vkbottle/__init__.py)
Чего не хватает? ![]()
