How to fix this on Aquamarine v1.1.4
How can I fix this issue with the photo? It happens when I teleport to another world in MCPE 1.1.5. It happens almost every time I teleport to another world, whether it’s the lobby or other worlds. Is there any way to fix it?
reference image:
Do the coordinates change a lot during teleportation?
Can you record a video?
мип это ты?
https://streamable.com/3fx2u5
Pls help, and @Marusel do you know fix this? Pls help
This video is in link
Yea that happens when you teleport to the same position but different world. Just like move your lobby to different coordinates
So… how could I fix it, or could you give me a recommendation to solve that?
You can try preloading the chunks before teleporting. Also, after the teleportation, the plugin should send a packet to the player that renders the chunks for them (since there is no guarantee that the server core handles this properly on its own).
Use world edit to copy/paste lobby to different coordinates.
Or also I think that can be fixed by setting render distance to 0 then back to normal. player.setViewDistance or something like that
Не в этом проблема
Думаешь?
Сервер исправно отправляет чанки, просто клиент не рассчитан на то что ему один и тот же чанк будет отправлен несколько раз
Thanks, bro, it worked for me! :smiley:
мип это ты?
