[LC 1.0.9] Help plugin
Помогите в чем ошибка?
2022-05-24 [02:46:10] [Server thread/ERROR]: [API] Плагин PurePerms НЕ найден, выключение плагина
2022-05-24 [02:46:10] [Server thread/CRITICAL]: pocketmine\plugin\PluginException: "Plugin 'API' attempted to register a task while disabled" (EXCEPTION) in "pmsrc/src/pocketmine/scheduler/ServerScheduler" at line 206
2022-05-24 [02:46:10] [Server thread/CRITICAL]: #0 pmsrc/src/pocketmine/scheduler/ServerScheduler(137): pocketmine\scheduler\ServerScheduler->addTask(object API\UndefinedTask, integer -1, integer 20)
2022-05-24 [02:46:10] [Server thread/CRITICAL]: #1 plugins/API/src/API/API(156): pocketmine\scheduler\ServerScheduler->scheduleRepeatingTask(object API\UndefinedTask, integer 20)
2022-05-24 [02:46:10] [Server thread/CRITICAL]: #2 pmsrc/src/pocketmine/plugin/PluginBase(86): API\API->onEnable()
2022-05-24 [02:46:10] [Server thread/CRITICAL]: #3 pmsrc/src/pocketmine/plugin/FolderPluginLoader(135): pocketmine\plugin\PluginBase->setEnabled(boolean 1)
2022-05-24 [02:46:10] [Server thread/CRITICAL]: #4 pmsrc/src/pocketmine/plugin/PluginManager(625): pocketmine\plugin\FolderPluginLoader->enablePlugin(object API\API)
2022-05-24 [02:46:10] [Server thread/CRITICAL]: #5 pmsrc/src/pocketmine/Server(2243): pocketmine\plugin\PluginManager->enablePlugin(object API\API)
2022-05-24 [02:46:10] [Server thread/CRITICAL]: #6 pmsrc/src/pocketmine/Server(2229): pocketmine\Server->enablePlugin(object API\API)
2022-05-24 [02:46:10] [Server thread/CRITICAL]: #7 pmsrc/src/pocketmine/Server(1929): pocketmine\Server->enablePlugins(integer 0)
2022-05-24 [02:46:10] [Server thread/CRITICAL]: #8 pmsrc/src/pocketmine/PocketMine(337): pocketmine\Server->__construct(object BaseClassLoader, object pocketmine\utils\MainLogger, string[32] /storage/emulated/0/Server/MCPE/, string[40] /storage/emulated/0/Server/MCPE/plugins/)
Читать умеем?
А нет. Ты запускаешь какую-то задачу, когда плагин ещё не включился
Чел, прикол в том, что юз правельный, и плагин присутствует
скинь функцию где ты таск добавляешь и скинь plugin.yml
в plugin.yml убери LOAD: STARTUP
где пожалуйста?
возвраждай старые темы, додик
И он не решил проблему, так что не лезь в чужые темы (которые были созданы летом 2022 года…)
