Небольшая проблемка с механизмами
Решил как то попробовать сделать на сервере рабочим механизмы, поставил Lite Core-Mod(мне нравится это ядро), закинул плагин, начало выдавать вот эту ошибку в консоле:
[Server thread/ERROR]: Невозможно загрузить ‘/home/plugins/RedStone’ в папке ‘/home/plugins/’: yaml_parse(): scanning error encountered during parsing: found character that cannot start any token (line 5, column 9), context while scanning for the next token (line 5, column 9)
[21:33:24] [Server thread/CRITICAL]: ErrorException: “yaml_parse(): scanning error encountered during parsing: found character that cannot start any token (line 5, column 9), context while scanning for the next token (line 5, column 9)” (EXCEPTION) in “pmsrc/src/pocketmine/plugin/PluginDescription” at line 52
[21:33:24] [Server thread/CRITICAL]: #0 (): pocketmine\utils\Utils::errorExceptionHandler(integer 2, string[181] yaml_parse(): scanning error encountered during parsing: found character that ca, string[49] /home/src/pocketmine/plugin/PluginDescription.php, integer 52)
[21:33:24] [Server thread/CRITICAL]: #1 pmsrc/src/pocketmine/plugin/PluginDescription(52): yaml_parse(string[260] name: RedStone…main: PHPDEV\RedStone…api: 3.0.0…version: 0.1…author: @snekky)
[21:33:24] [Server thread/CRITICAL]: #2 pmsrc/src/pocketmine/plugin/FolderPluginLoader(103): pocketmine\plugin\PluginDescription->__construct(string[260] name: RedStone…main: PHPDEV\RedStone…api: 3.0.0…version: 0.1…author: @snekky)
[21:33:24] [Server thread/CRITICAL]: #3 pmsrc/src/pocketmine/plugin/PluginManager(206): pocketmine\plugin\FolderPluginLoader->getPluginDescription(string[22] /home/plugins/RedStone)
[21:33:24] [Server thread/CRITICAL]: #4 pmsrc/src/pocketmine/Server(1930): pocketmine\plugin\PluginManager->loadPlugins(string[14] /home/plugins/)
[21:33:24] [Server thread/CRITICAL]: #5 pmsrc/src/pocketmine/PocketMine(320): pocketmine\Server->__construct(object BaseClassLoader, object pocketmine\utils\MainLogger, string[6] /home/, string[14] /home/plugins/)
Кто поможет, буду очень благодарен. Если нужен плагин, могу прикрепить.
Поинтересуюсь, какой у тебя LiteCore? На LiteCore 1.0.9 не работают механизмы и BossBar
именно он, на 1.0.8 работает?
вроде как работает, но мне нужны поршни
Меня одного волнует один вопрос: Почему тема в Обратном связи?
Кинь репорт
А так да, провтыкал малость я
Ну да, причем сдесь Ниггерия
