Помогите с ошибкой :0
Сама ошибка:
Warning: socket_connect(): unable to connect [111]: Connection refused in /www/engine/ajax/minestat.php on line 50
Сервер не работает
Сам minestat.php:
Minestat
Скрином
Файлом
minestat.php (3.4 КБ)
Кодом (незнаю зачем :| но пусть будет :))
 * minestat.php - A Minecraft server status checker
 * Copyright (C) 2014 Lloyd Dilley
 * http://www.dilley.me/
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 3 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License along
 * with this program; if not, write to the Free Software Foundation, Inc.,
 * 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
class MineStat
  const DATA_SIZE = 512;    // this will hopefully suffice since the MotD should be <=59 characters
  const NUM_FIELDS = 6;     // number of values expected from server "6"
  private $address;
  private $port;
  private $online;          // online or offline?
  private $version;         // Minecraft server version
  private $motd;            // message of the day
  private $current_players; // current number of players online
  private $max_players;     // maximum player capacity
  private $latency;         // ping time to server in milliseconds
  public function __construct($address, $port, $timeout = 5)
    $this->address = $address;
    $this->port = $port;
    try
      $socket = socket_create(AF_INET, SOCK_STREAM, SOL_TCP);
      socket_set_option($socket, SOL_SOCKET, SO_RCVTIMEO, array('sec' => $timeout, 'usec' => 0));
      if($socket === false)
        $this->online = false;
      $start_time = microtime();
      $result = socket_connect($socket, $address, $port);
      $this->latency = round((microtime() - $start_time) * 1000);
      if($result === false)
      $payload = "\xFE\x01";
      socket_write($socket, $payload, strlen($payload));
      $raw_data = socket_read($socket, MineStat::DATA_SIZE);
      socket_close($socket);
    catch(Exception $e)
    if(isset($raw_data))
      $server_info = explode("\x00\x00\x00", $raw_data);
      if(isset($server_info) && sizeof($server_info) >= MineStat::NUM_FIELDS)
        $this->online = true;
        $this->version = $server_info[2];
        $this->motd = $server_info[3];
        $this->current_players = $server_info[4];
        $this->max_players = $server_info[5];
      else
    else
  public function get_address()
    return $this->address;
  public function get_port()
    return $this->port;
  public function is_online()
    return $this->online;
  public function get_version()
    return $this->version;
  public function get_motd()
    return $this->motd;
  public function get_current_players()
    return $this->current_players;
  public function get_max_players()
    return $this->max_players;
  public function get_latency()
    return $this->latency;
Код от куда берётся онлайн
require_once('minestat.php');
$ms = new MineStat("test.ru", 19132); // PE / JE
if($ms->is_online())
  printf("ТЕКУЩИЙ ОНЛАЙН: %s", $ms->get_current_players());
else
  printf("Сервер не работает<br>");
Спасибо большое кто поможет :>
Питонист писал код 100%
Перед socket_create тебе сначала нужно его забиндить (socket_bind)
$socket = fsockopen("udp://"."127.0.0.1" , 19132);
stream_set_timeout($socket, 1);
fwrite($socket, base64_decode("AX//////////AP//AP7+/v79/f39EjRWeH//////////"));
if(($data = fread($socket, 4096)) !== false){
	if(isset($data[4])){
		$online = explode(";", substr($data, 35))[4];
		echo "<a><font color='white'> Сейчас играет <font color='purple'>{$online}</font> игроков</font></a>";
		echo "<a><font color='red'> Сервер выключен</font></a>";
@pat228
Я те скинул адекватный код
Это куда заливать, где получать онлайн, или в Minestat?
Можно прям в код хтмл
Да не, так не хочу :slight_smile:
В любом случае, я тебе сказал решение
я в motd не разбераюсь :0
Сокеты это не мотд
ок, напиши в вк :0
Помогать хейтеру русских не буду
Я не хейтер, просто поставил Украинский флаг
просто флаг поставил
Та за шо меня то
Афамьев сто проц накидал жалоб
Чел меня даже в онлайне не было, пхпхпххп
