namespace wmpe;
use ClanSystem\War\WarHandler;
use pocketmine\entity\Projectile;
use pocketmine\event\block\BlockBreakEvent;
use pocketmine\event\block\ItemFrameDropItemEvent;
use pocketmine\event\entity\EntityDamageByEntityEvent;
use pocketmine\event\entity\EntityDamageEvent;
use pocketmine\event\entity\EntityTeleportEvent;
use pocketmine\event\entity\ProjectileLaunchEvent;
use pocketmine\event\inventory\CraftItemEvent;
use pocketmine\event\inventory\InventoryPickupArrowEvent;
use pocketmine\event\inventory\InventoryPickupItemEvent;
use pocketmine\event\inventory\InventoryTransactionEvent;
use pocketmine\event\player\PlayerCommandPreprocessEvent;
use pocketmine\event\player\PlayerDropItemEvent;
use pocketmine\event\player\PlayerInteractEvent;
use pocketmine\event\player\PlayerItemConsumeEvent;
use pocketmine\event\player\PlayerLoginEvent;
use pocketmine\event\player\PlayerMoveEvent;
use pocketmine\event\player\PlayerQuitEvent;
use pocketmine\inventory\BaseTransaction;
use pocketmine\inventory\PlayerInventory;
use pocketmine\Server;
use pocketmine\utils\Config;
use SQLite3;
use function array_shift;
use function crypt;
use function explode;
use function in_array;
use function md5;
use function min;
use function sha1;
use function strtolower;
use function substr;
use function time;
use const SQLITE3_ASSOC;
use const SQLITE3_TEXT;
class wAuth extends PluginBase implements Listener{
* @var array
* эти команды не будут проверяться на то, не авторизован ли игрок. Или если команда не взаимодействует с игроками
const COMMANDS_EXCEPTION = [
"/ban", "/kick", "/ban-ip",
"/bantime", "/kill", "/mute",
"/warp", "/rg", "/ban", "/kit",
/** @var SQLite3 */
private $db;
private $users = [], $reg = [];
/** @var Config */
private $blockedPlayers;
public function onEnable(){
if(!is_dir($this->getDataFolder()))
$this->config = (new Config($this->getDataFolder() . "config.yml", Config::YAML, ["salt" => "ТвойКлючШифрования"]))->getAll();
/** @var SQLite3 db */
$this->db = new SQLite3($this->getDataFolder() . "users.db");
$this->db->exec(stream_get_contents($this->getResource("database.sql")));
$this->blockedPlayers = new Config($this->getDataFolder() . "blocked_players.json", Config::JSON);
$changed = false;
foreach($this->blockedPlayers->getAll() as $identifier => $blockedUntil){
if($blockedUntil <= time()){
$changed = true;
$this->blockedPlayers->remove($identifier);
if($changed)
$this->blockedPlayers->save();
/** @var wAuth */
private static $instance;
public function onLoad(){
self::$instance = $this;
public static function getInstance() : wAuth{
return self::$instance;
public function hasLogined(Player $player) : bool{
return isset($this->users[strtolower($player->getName())]);
public function onDrop(PlayerDropItemEvent $e){
$player = $e->getPlayer();
if(!isset($this->users[$player->getLowerCaseName()])){
$player->sendMessage('§7► §cНельзя выкидывать предметы, пока ты не авторизуешься!');
$e->setCancelled(true);
public function onBreak(BlockBreakEvent $e){
$player->sendMessage('§7► §cНельзя взаимодействовать с сервером, пока ты не авторизуешься!');
* @param PlayerInteractEvent $e
* @noinspection PhpUnused
* @ignoreCancelled true
* @priority LOWEST
public function onTap(PlayerInteractEvent $e){
$player->sendPopup('§7► §cНельзя взаимодействовать с сервером, пока ты не авторизуешься!');
public function onLogin(PlayerLoginEvent $event){
$address = $player->getAddress();
$clientId = $player->getClientId();
if(!$this->blockedPlayers->exists($address) and !$this->blockedPlayers->exists($clientId)){
$byAddress = (int)$this->blockedPlayers->get($address, -1);
$byClientId = (int)$this->blockedPlayers->get($clientId, -1);
$blockedUntil = max($byAddress, $byClientId);
if($blockedUntil > ($currentTime = time())){
$timeLeft = function() use ($blockedUntil, $currentTime) : string{
$time = $blockedUntil - $currentTime;
$minutes = (int)($time / 60);
$time = $time - $minutes * 60;
$seconds = (int)$time;
$result = "";
$array = ["м." => $minutes, "с." => $seconds];
foreach($array as $key => $value){
if($value > 0){
$result .= $value . " " . $key . " ";
return substr($result, 0, -1);
$event->setCancelled(true);
$player->kick("§7* §cВы временно заблокированы за ввод неверного пароля.\n§7* §cВы сможете зайти через §e" . $timeLeft() . ".", false);
public function onPlayerJoin(PlayerJoinEvent $event){
$sql = $this->db->prepare("SELECT * FROM `users` WHERE `nickname` = :nickname");
$sql->bindValue(":nickname", strtolower($player->getName()), SQLITE3_TEXT);
$sql = $sql->execute();
$user = $sql->fetchArray(SQLITE3_ASSOC);
if(isset($user["nickname"])){
$player->sendMessage("\n§r§7Для авторизации на сервере, отправьте §bсвой пароль §7в чат. Его никто не увидит!\n");
$player->setImmobile(true);
$player->sendMessage("\n§r§7Пожалуйста, §bзарегистрируйтесь, §7отправьте свой пароль в чат. Его никто не увидит!\n");
$sql->finalize();
public function onPlayerQuit(PlayerQuitEvent $event){
if(($player = $event->getPlayer())->loggedIn and isset($this->users[$playerName = strtolower($player->getName())])){
unset($this->users[$playerName]);
private $attempts = [];
* @param PlayerCommandPreprocessEvent $event
* @priority LOWEST
public function onPlayerCommandPreprocess(PlayerCommandPreprocessEvent $event){
$login = "§r§7Введите §bсвой пароль §7в чат, который вводили при регистрации.";
$name = strtolower($player->getName());
$ip = $player->getAddress();
$msg = $event->getMessage();
if(!isset($this->users[$name])){
if(count(explode("/", $msg)) > 1){
$player->sendMessage($login);
$msg = explode(" ", $msg);
if(count($msg) == 1){
$sql->bindValue(":nickname", $name, SQLITE3_TEXT);
if($sql instanceof \SQLite3Result){
$pass = crypt(md5($rawPass = $msg[0]), sha1($this->config["salt"]));
if(!empty($user["nickname"])){
if($pass == $user["password"]){
$upd = $this->db->prepare("UPDATE `users` SET `ipLast` = :ip WHERE `nickname` = :nickname");
$upd->bindValue(":ip", $ip);
$upd->bindValue(":nickname", $name);
$upd = $upd->execute();
$upd->finalize();
$this->users[$name] = ["pass" => $pass, "ip" => $ip];
$player->sendMessage("\n§r§7Вы успешно §aавторизировались §7на сервере. Приятной игры!\n\n§a§l› §f§rНайди других игроков §e§l/warp surv\n§a§l› §f§rПомощь по серверу §e§l/help\n");
unset($this->attempts[$name]);
$player->setImmobile(false);
if (strlen($rawPass) <= 5) {
$player->sendMessage("\n§r§7Ваш пароль слишком §aкороткий. Советуем вам его изменить на более длинный!\n\n");
if(!isset($this->attempts[$name]))
$this->attempts[$name] = 0;
if(++$this->attempts[$name] < 3){
$number = 3 - $this->attempts[$name];
$player->sendMessage("§r§7 Вы ввели §cневерный пароль. §7У вас " . ($number !== 1 ? "осталось" : "осталась") . " §6" . $number . " " . $this->convert($number, "попытка,попытки, попыток") . "!");
$this->blockPlayer($player);
if(!isset($this->reg[$name])){
$player->sendMessage("\n§r§7Ваш пароль слишком §aкороткий. Минимум 6 символов!\n\n");
$this->reg[$name] = $pass;
$player->sendMessage("§r§7Для подтверждения, введите §b<свой пароль> §7в чат повторно!");
if($pass == $this->reg[$name]){
$add = $this->db->prepare("INSERT INTO `users`(`nickname`, `password`, `ipReg`, `ipLast`) VALUES(:nickname, :password, :ip, :ip)");
$add->bindValue(":nickname", $name);
$add->bindValue(":password", $pass);
$add->bindValue(":ip", $ip);
$add = $add->execute();
$add->finalize();
$player->sendMessage("\n§r§7Вы успешно §aзарегистрировались, §7не забудьте свой пароль или запишите его!\n\n§fПомощь по серверу §e/help\n\n§a§l| §r§fНайди других игроков §e§l/warp surv\n\n§a§l| §r§fТвой пароль §c➤ §a". $rawPass .'§r');
unset($this->reg[$name]);
$player->sendMessage("§7\nВы ввели §cневерный пароль.\n");
$sql->finalize();
}else $player->sendMessage($login);
if($ip != $this->users[$name]["ip"]){
private function convert($n, $a){
$a = explode(",", $a);
$cases = [2, 0, 1, 1, 1, 2];
return $a[($n % 100 > 4 and $n % 100 < 20) ? 2 : $cases[min($n % 10, 5)]];
const BLOCK_MINUTES = 15;
private function blockPlayer(Player $player){
unset($this->attempts[strtolower($player->getName())]);
$player->kick("§7* §cВы ввели неверный пароль более §b2-х раз.\n§7* §cПопробуйте снова через §e15 минут.", false);
$this->blockedPlayers->set($player->getAddress(), time() + 60 * wAuth::BLOCK_MINUTES);
$this->blockedPlayers->set($player->getClientId(), time() + 60 * wAuth::BLOCK_MINUTES);
const MIN_LENGTH = 6;
public function onCommand(CommandSender $player, Command $command, $commandLabel, array $args){
if($command->getName() == 'changepassword'){
if(!$player instanceof Player){
$player->sendMessage("§cКоманду /" . $commandLabel . " можно использовать только в игре!");
if(!isset($args[1])){
$player->sendMessage("§r §cФормат использования: §a/" . $commandLabel . " (текущий пароль) (новый пароль)");
$sql->finalize();
if(!isset($user["password"])){
$player->sendMessage("§8§l(§cUnder§eWorld§8)§r §cПроизошла ошибка. Невозможно сменить пароль");
$dbPassword = $user["password"];
$currentPassword = crypt(md5(array_shift($args)), sha1($this->config["salt"]));
if($dbPassword != $currentPassword){
$player->sendMessage("§r §cПароль от этого аккаунта не совпадает с введённым.");
$newPassword = crypt(md5($rawPassword = array_shift($args)), sha1($this->config["salt"]));
if(!isset($rawPassword{wAuth::MIN_LENGTH - 1})){
$player->sendMessage("§r §cНовый пароль слишком короткий!");
if(strtolower($rawPassword) === strtolower($player->getName())){
$player->sendMessage("§r §cНовый пароль не должен совпадать с вашим никнеймом!");
$this->changePassword($player, $newPassword);
$player->sendMessage("§r §aВы успешно поменяли свой пароль на §6" . $rawPassword);
}elseif($command->getName() == 'unregister'){
if($player instanceof Player){
$player->sendMessage("§cНедостаточно прав для использования команды /" . $commandLabel . "!");
if(!isset($args[0])){
$player->sendMessage("§r► §cФормат использования: §a/" . $commandLabel . " (имя игрока полностью)");
$playerName = strtolower(array_shift($args));
$sql->bindValue(":nickname", $playerName, SQLITE3_TEXT);
$sql->finalize();
if(!isset($user["nickname"])){
$player->sendMessage("§r► §cИгрок §a". $playerName ." §cне зарегистрирован на сервере!");
$sql = $this->db->prepare("DELETE FROM `users` WHERE `nickname` = :nickname");
$sql->finalize();
$player->sendMessage("§r► §eПароль игрока §a". $playerName ." §eбыл успешно сброшен!");
$playerInstance = Server::getInstance()->getPlayerExact($playerName);
if($playerInstance instanceof Player and $playerInstance->isOnline()){
$playerInstance->kick('§7► §eВаш пароль был сброшен администрацией! §7◄', false);
public function changePassword(Player $player, string $newPassword){
$upd = $this->db->prepare("UPDATE `users` SET `password` = :password WHERE `nickname` = :nickname");
$upd->bindValue(":nickname", $playerName = strtolower($player->getName()));
$upd->bindValue(":password", $newPassword);
$this->users[$playerName]["pass"] = $newPassword;
$upd->finalize();
* @param EntityDamageEvent $event
* @priority LOWEST
public function onDamage(EntityDamageEvent $event){
$player = $event->getEntity();
if($event instanceof EntityDamageByEntityEvent){
$damager = $event->getDamager();
if($damager instanceof Player){
if(!isset($this->users[$damager->getLowerCaseName()])){
$damager->sendMessage('§7► §cАвторизуйся чтобы атаковать других игроков!');
* @param ItemFrameDropItemEvent $event
* @priority LOWEST
public function onFrame(ItemFrameDropItemEvent $event){
$player->sendMessage('§7► §cНельзя взаимодействовать с рамками, пока ты не авторизуешься!');
/** @noinspection PhpUnused */
public function onTeleport(EntityTeleportEvent $event){
if($event->isCancelled()){
public function onPickupItem(InventoryPickupItemEvent $event){
$inventory = $event->getInventory();
if(!$inventory instanceof PlayerInventory){
$player = $inventory->getHolder();
public function onPickupArrow(InventoryPickupArrowEvent $event){
public function onCraftItem(CraftItemEvent $event){
$player->sendMessage('§7► §cНельзя крафтить, пока ты не авторизуешься!');
public function onItemConsume(PlayerItemConsumeEvent $event){
$player->sendMessage('§7► §cНельзя кушать, пока ты не авторизуешься!');
public function onTransaction(InventoryTransactionEvent $event){
$queue = $event->getQueue();
/** @var BaseTransaction $transaction */
foreach($queue->getTransactions() as $transaction){
$inventory = $transaction->getInventory();
if($inventory instanceof PlayerInventory){
$player->sendPopup('§7► §cАвторизуйся для взаимодействия с сервером! §7◄');
public function onProjectileLaunch(ProjectileLaunchEvent $event){
$entity = $event->getEntity();
if(!$entity instanceof Projectile){
$player = $entity->getOwningEntity();
public function onPreprocess(PlayerCommandPreprocessEvent $event){
$message = $event->getMessage();
if(substr($message, 0, 1) === "/"){
$args = explode(" ", $message);
$command = array_shift($args);
if(in_array($command, wAuth::COMMANDS_EXCEPTION, true)){
foreach($args as $arg){
$target = Server::getInstance()->getPlayer($arg);
if($target instanceof Player and $target->isOnline() and !isset($this->users[$target->getLowerCaseName()])){
$player->sendMessage("§7► §cНевозможно выполнить эту команду! §b" . $target->getName() . " §cне авторизован!");
ок
Как называется ивент где игроку обратно выдаётся лут в инвентарь?
Там на авторизации кидаешь ресы и они обратно все выдаются но дюпаются
И когда авторизируешься ресы не проподают(
\pocketmine\event\player\PlayerDropItemEvent
Вот тут надо сделать чтобы ресы не шли обратно а просто не кидались
тебе сверху сказали что делать
нихуя не понял
А там что делать?
function drop(PlayerDropItemEvent $event) : void{if (!isset($this->users[$player->getLowerCaseName()])):$event->cancel();endif;}
это в плагин?
нет бля, в жопу себе засунь
Шо за вирусы
какие
крашит
покажи как ты вставил
Неправильно походу(
