Помогитея ядро сломано
Когда убиваешь человека в другом мире спасибо в консоле и кикает игрока,
Направление src/pocketmine/level/generator/flat.php
Ядро FrozenCore из сборки UnderWorld
Code:
?php
* __ _ _ __ __ _ __ __ __
* | _ \ __ __| | ____| |_| \/ (_)_ __ __ | \/ | _ \
* | |_) / _ \ / __| |/ / _ \ __| |\/| | | '_ \ / _ \_____| |\/| | |_) |
* | __/ (_) | (__| < __/ |_| | | | | | | | __/_____| | | | __/
* |_| \__/ \__|_|\_\__|\__|_| |_|_|_| |_|\__| |_| |_|_|
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU Lesser General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* @author PocketMine Team
* @link http://www.pocketmine.net/
namespace pocketmine\level\generator;
use pocketmine\block\Block;
use pocketmine\item\Item;
use pocketmine\level\ChunkManager;
use pocketmine\level\format\Chunk;
use pocketmine\level\generator\object\OreType;
use pocketmine\level\generator\populator\Ore;
use pocketmine\level\generator\populator\Populator;
use pocketmine\math\Vector3;
use pocketmine\utils\Random;
use function array_map;
use function count;
use function explode;
use function preg_match;
use function preg_match_all;
class Flat extends Generator{
/\*\* @var Chunk \*/
private $chunk;
/\*\* @var Populator\[\] \*/
private $populators = \[\];
/\*\* @var int\[\]\[\] \*/
private $structure;
/\*\* @var int \*/
private $floorLevel;
/\*\* @var int \*/
private $biome;
/\*\* @var mixed\[\] \*/
private $options;
/\*\* @var string \*/
private $preset;
 \* @return array
public function getSettings(){
	return $this->options;
 \* @return string
public function getName() : string{
	return "flat";
 \* @param array $options
 \* @throws InvalidGeneratorOptionsException
public function \__construct(array $options = \[\]){
	$this->options = $options;
	if(isset($this->options\["preset"\]) and $this->options\["preset"\] != ""){
		$this->preset = $this->options\["preset"\];
		$this->preset = "2;7,2x3,2;1;";
		//$this->preset = "2;7,59x1,3x3,2;1;spawn(radius=10 block=89),decoration(treecount=80 grasscount=45)";
	$this->parsePreset();
	if(isset($this->options\["decoration"\])){
		$ores = new Ore();
		$ores->setOreTypes(\[
			new OreType(Block::get(Block::COAL_ORE), 20, 16, 0, 128),
			new OreType(Block::get(Block::IRON_ORE), 20, 8, 0, 64),
			new OreType(Block::get(Block::REDSTONE_ORE), 8, 7, 0, 16),
			new OreType(Block::get(Block::LAPIS_ORE), 1, 6, 0, 32),
			new OreType(Block::get(Block::GOLD_ORE), 2, 8, 0, 32),
			new OreType(Block::get(Block::DIAMOND_ORE), 1, 7, 0, 16),
			new OreType(Block::get(Block::DIRT), 20, 32, 0, 128),
			new OreType(Block::get(Block::GRAVEL), 10, 16, 0, 128)
		$this->populators\[\] = $ores;
 \* @param string $layers
 \* @return int\[\]\[\]
public static function parseLayers(string $layers) : array{
	$result = \[\];
	$split = array_map('\\trim', explode(',', $layers));
	$y = 0;
	foreach($split as $line){
		preg_match('#^(?:(\\d+)\[x|\*\])?(.+)$#', $line, $matches);
		if(count($matches) !== 3){
			throw new InvalidGeneratorOptionsException("Invalid preset layer \\"$line\\"");
		$cnt = $matches\[1\] !== "" ? (int) $matches\[1\] : 1;
		try{
		}catch(\\InvalidArgumentException $e){
			throw new InvalidGeneratorOptionsException("Invalid preset layer \\"$line\\": " . $e->getMessage(), 0, $e);
		for($cY = $y, $y += $cnt; $cY < $y; ++$cY){
			$result\[$cY\] = \[$b->getId(), $b->getDamage()\];
	return $result;
protected function parsePreset() : void{
	$preset = explode(";", $this->preset);
	$blocks = (string) ($preset\[1\] ?? "");
	$this->biome = (int) ($preset\[2\] ?? 1);
	$options = (string) ($preset\[3\] ?? "");
	$this->structure = self::parseLayers($blocks);
	$this->floorLevel = count($this->structure);
	//TODO: more error checking
	preg_match_all('#((\[0-9a-z\_\]{1,})\\(?(\[0-9a-z\_ =:\]{0,})\\)?),?#', $options, $matches);
	foreach($matches\[2\] as $i => $option){
		$params = true;
		if($matches\[3\]\[$i\] !== ""){
			$params = \[\];
			$p = explode(" ", $matches\[3\]\[$i\]);
			foreach($p as $k){
				$k = explode("=", $k);
				if(isset($k\[1\])){
					$params\[$k\[0\]\] = $k\[1\];
		$this->options\[$option\] = $params;
protected function generateBaseChunk() : void{
	$this->chunk = new Chunk(0, 0);
	$this->chunk->setGenerated();
	for($Z = 0; $Z < 16; ++$Z){
		for($X = 0; $X < 16; ++$X){
			$this->chunk->setBiomeId($X, $Z, $this->biome);
	$count = count($this->structure);
	for($sy = 0; $sy < $count; $sy += 16){
		$subchunk = $this->chunk->getSubChunk($sy >> 4, true);
		for($y = 0; $y < 16 and isset($this->structure\[$y | $sy\]); ++$y){
			list($id, $meta) = $this->structure\[$y | $sy\];
					$subchunk->setBlock($X, $y, $Z, $id, $meta);
public function init(ChunkManager $level, Random $random) : void{
	parent::init($level, $random);
	$this->generateBaseChunk();
public function generateChunk($chunkX, $chunkZ){
	$chunk = clone $this->chunk;
	$chunk->setX($chunkX);
	$chunk->setZ($chunkZ);
	$this->level->setChunk($chunkX, $chunkZ, $chunk);
public function populateChunk($chunkX, $chunkZ){
	$this->random->setSeed(0xdeadbeef ^ ($chunkX << 8) ^ $chunkZ ^ $this->level->getSeed());
	foreach($this->populators as $populator){
		$populator->populate($this->level, $chunkX, $chunkZ, $this->random);
public function getSpawn(){
	return new Vector3(128, $this->floorLevel, 128);
Т9 исправил, короче когда убиваешь игрока в другом мире в консоле начинает спамить и кикает игрока
Что консоль спамит, самим гадать? И при чем тут flat
пожалуйста
нахуя тут везде экранирование?
как я вижу ты каждые темы здесь хуесосишь, как фрик
ну так есть за что
PHPDoc называется
экранирования не только в коментариях
пиздeц ты еблан
услышал тебя брат
оно тупое.
поскули
