ошибка
[22:24:30] [Server thread/CRITICAL]: "Could not pass event ‘pocketmine\event\entity\EntityDamageByEntityEvent’ to ‘TransferNPC v1’: Undefined offset: 1 on TransferNPC\AnonymousPL
[22:24:30] [Server thread/CRITICAL]: ErrorException: “Undefined offset: 1” (EXCEPTION) in “plugins/TransferNPC/src/TransferNPC/AnonymousPL” at line 94
код
namespace TransferNPC;
use pocketmine\Server;
use pocketmine\tile\Tile;
use pocketmine\item\Item;
use pocketmine\block\Block;
use pocketmine\utils\Config;
use pocketmine\math\Vector3;
use pocketmine\entity\Entity;
use pocketmine\event\player\PlayerQuitEvent;
use pocketmine\event\entity\EntityDamageEvent;
use pocketmine\event\entity\EntityDamageByEntityEvent;
use pocketmine\command\{CommandSender, Command};
use pocketmine\nbt\tag\{CompoundTag, IntTag, StringTag, DoubleTag, FloatTag, ListTag, ShortTag};
class AnonymousPL extends PluginBase implements Listener{
public $mode = [];
public function onEnable(){
public function onCommand(CommandSender $sender, Command $command, $label, array $args){
if($command->getName() == "tnpc"){
if(!$sender->isOp()){
return $sender->sendMessage("§l§cНет прав!");
if(!isset($args[0])){
return $sender->sendMessage("§l§cИспользование: /tnpc <create|remove>");
switch($args[0]){
case "create":
if(!isset($args[3])){
$sender->sendMessage("§l§cИспользование: /tnpc create <размер> <ip:port>");
if(count(explode(":", $args[2])) < 2){
$sender->sendMessage("§l§cНе верный формат адреса сервера. Используйте /tnpc create <размер> <ip:port>");
if(!is_numeric($args[1])){
$sender->sendMessage("§l§cНе верный формат размера. Используйте /tnpc create <размер> <ip:port>");
array_shift($args);
$this->setNpc($sender, $args);
case "remove":
$this->removeNPC($sender);
default:
public function removeNPC($player){
$this->mode[$player->getName()] = "remove";
$player->sendMessage("§l§fНажмине на §eNPC §fкоторую хотите удалить\n§l§eЧтобы отменить напишите \"§bcancel§e\" в чат");
public function onQuit(PlayerQuitEvent $ev){
$player = $ev->getPlayer();
if(isset($this->mode[$player->getName()])){
unset($this->mode[$player->getName()]);
public function onDamage(EntityDamageEvent $ev){
$entity = $ev->getEntity();
if(isset($entity->namedtag->Address)){
$ev->setCancelled();
if($ev instanceof EntityDamageByEntityEvent){
$damager = $ev->getDamager();
if($damager instanceof Player){
if(isset($this->mode[$damager->getName()])){
unset($this->mode[$damager->getName()]);
$damager->sendMessage("§l§fВы §aуспешно §fудалили NPC для перехода на §e{$entity->namedtag->Address}");
$entity->kill();
$entity->close();
$address = explode(":", (string) $entity->namedtag->Address);
$damager->transfer($address[0], $address[1]);
public function onChat(PlayerChatEvent $ev){
if($ev->getMessage() == "cancel" and isset($this->mode[$player->getName()])){
public function setNpc($player, $settings){
$size = array_shift($settings);
$address = array_shift($settings);
$nbt = new CompoundTag;
$nbt->Pos = new ListTag("Pos", [
new DoubleTag(0, $player->getX()),
new DoubleTag(1, $player->getY()),
new DoubleTag(2, $player->getZ())
$nbt->Motion = new ListTag("Motion", [
new DoubleTag(0, $player->getMotion()->x),
new DoubleTag(1, $player->getMotion()->y),
new DoubleTag(2, $player->getMotion()->z)
$nbt->Rotation = new ListTag("Rotation", [
new FloatTag(0, $player->getYaw()),
new FloatTag(1, $player->getPitch())
$nbt->Health = new ShortTag("Health", 1);
$nbt->Address = new ShortTag("Address", $address);
$player->saveNBT();
$nbt->Skin = new CompoundTag("Skin", [
"Data" => new StringTag("Data", $player->getSkinData()),
"Name" => new StringTag("Name", $player->getSkinId())
$entity = Entity::createEntity("Human", $player->getLevel(), $nbt);
$entity->setNameTag(" §6РЕЖИМ АНАРХИЯ\n§7ТАПНИ ЧТОБЫ ПРИСОЕДИНИТСЯ\n");
$entity->setNameTagVisible(true);
$entity->setNameTagAlwaysVisible(true);
$entity->setScale($size);
$entity->spawnToAll();
$player->sendMessage("§l§fСтатуя для перехода на сервер §e{$address}§f, §aуспешно §fустановленна!");
