в чем здесь ошибка?
ErrorException: “file_put_contents(/home/auto.yml): failed to open stream: Permission denied” (EXCEPTION) in “pmsrc/src/pocketmine/utils/Config” at line 211
[16:53:53] [Aquamarine/CRITICAL]: #0 (): pocketmine\utils\Utils::errorExceptionHandler(integer 2, string[75] file_put_contents(/home/auto.yml): failed to open stream: Permission denied, string[67] phar:///srv/data/PocketMine-MP.phar/src/pocketmine/utils/Config.php, integer 211, array[1])
[16:53:53] [Aquamarine/CRITICAL]: #1 pmsrc/src/pocketmine/utils/Config(211): file_put_contents(string[14] /home/auto.yml, string[11] — []…)
[16:53:53] [Aquamarine/CRITICAL]: #2 pmsrc/src/pocketmine/utils/Config(137): pocketmine\utils\Config->save()
[16:53:53] [Aquamarine/CRITICAL]: #3 pmsrc/src/pocketmine/utils/Config(83): pocketmine\utils\Config->load(string[14] /home/auto.yml, integer 2, array[0])
[16:53:53] [Aquamarine/CRITICAL]: #4 plugins/sws/src/sws/sws(34): pocketmine\utils\Config->__construct(string[14] /home/auto.yml, integer 2)
[16:53:53] [Aquamarine/CRITICAL]: #5 pmsrc/src/pocketmine/plugin/PluginBase(86): sws\sws->onEnable()
[16:53:53] [Aquamarine/CRITICAL]: #6 pmsrc/src/pocketmine/plugin/FolderPluginLoader(135): pocketmine\plugin\PluginBase->setEnabled(boolean 1)
[16:53:53] [Aquamarine/CRITICAL]: #7 pmsrc/src/pocketmine/plugin/PluginManager(625): pocketmine\plugin\FolderPluginLoader->enablePlugin(object sws\sws)
[16:53:53] [Aquamarine/CRITICAL]: #8 pmsrc/src/pocketmine/Server(2253): pocketmine\plugin\PluginManager->enablePlugin(object sws\sws)
[16:53:53] [Aquamarine/CRITICAL]: #9 pmsrc/src/pocketmine/Server(2239): pocketmine\Server->enablePlugin(object sws\sws)
[16:53:53] [Aquamarine/CRITICAL]: #10 pmsrc/src/pocketmine/Server(2020): pocketmine\Server->enablePlugins(integer 1)
[16:53:53] [Aquamarine/CRITICAL]: #11 pmsrc/src/pocketmine/PocketMine(328): pocketmine\Server->__construct(object BaseClassLoader, object pocketmine\utils\MainLogger, string[10] /srv/data/, string[18] /srv/data/plugins/)
[16:53:53] [Aquamarine/CRITICAL]: #12 pmsrc(1): require_once(string[65] phar:///srv/data/PocketMine-MP.phar/src/pocketmine/PocketMine.php)
